Date/Time: Wed, 15 Jan 2025 12:37:51 +0000
Adding shaded zones and lines to a chart
View Count: 1440
[2017-07-31 07:03:31] |
User583039 - Posts: 7 |
I want to add shaded zones to a chart (see uploaded image) like what's shown in purple and blue. Please point me to the specific resource on how to do this. I also want to add orange dotted lines with tags (see uploaded image) to my chart. Please point me to the specific resource on how to do this. I will be using a 6 tick Point & Figure (reversal) bar type with the number bars study (see attached image). It starts a new bar after 6 ticks from the high or low of the current bar. I want it to mark exactly where the new bar started. How do I do this? |
Sierra DTG chart.png / V - Attached On 2017-07-31 06:56:12 UTC - Size: 107.52 KB - 362 views |
[2017-07-31 18:33:20] |
1. Refer to the documentation here for this: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study 2. Use the "Line" study: Line 3. Do you mean you want to see the open price of a bar marked? If so, then refer to this Input with the Numbers Bars study: Numbers Bars: Open and Close Marker Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-31 18:34:46
