Date/Time: Wed, 15 Jan 2025 12:46:35 +0000
Replay: MTF Crossover Problem
View Count: 5964
[2017-07-31 04:26:40]
User312841 - Posts: 26
http://www.sierrachart.com/image.php?Image=150147385713.png
The crossover always works fine as a Color background on Alert (Blue line)
=CROSSFROMBELOW(ID3.SG1,ID1.SG1)
Magenta line
=(CROSSFROMABOVE(ID3.SG1,ID1.SG1))
ID3 is in a 3T Renko, ID1 is from a 9T Renko chart (Blue and Magenta stair step)
The problem is when using the Spreadsheet to autotrade in Replay Mode. The first trigger places the trade but the Buy Exit never trips.
Spreadsheet Buy Entry
=AND(CROSSFROMBELOW(ID3.SG1@3:ID3.SG1@4,ID1.SG1@3:ID1.SG1@4),$J$8 = 0) **Places trade OK**
Buy Exit
=AND(CROSSFROMABOVE(ID3.SG1@3:ID3.SG1@4,ID1.SG1@3:ID1.SG1@4),$J$8 > 0)
Attached is a file with the higher timeframe settings. What am i missing? Thanks
imageCapture.PNG / V - Attached On 2017-07-31 04:22:51 UTC - Size: 24.97 KB - 295 views
[2017-07-31 16:52:39]
Update to the current version of Sierra Chart following these instructions:
Also try setting Data Copy Mode to Use Latest Value.
Buy Exit
Does this formula ever return 1 at any row?
[2017-07-31 17:43:44]
Tried using Latest Value - did not help
I never saw a 1, but recall seeing a #VALUE displayed several rows down.
[2017-07-31 18:17:33]
In this case, then you need to look at the particular cells being referenced by the formula and see why those are not as expected.
