Date/Time: Wed, 15 Jan 2025 12:59:34 +0000
Triggered Trailing Stop
View Count: 2289
[2017-07-29 18:14:34] |
Samuel - Posts: 8 |
Hi, When using Triggered Trailing Stop as a PARENT order in ACSIL, which member correspond to the trigger price and which to the stop price? NewOrder.OrderType = SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS; NewOrder.Price1 = <stop price>; NewOrder.TriggeredTrailStopTriggerPriceOffset = <trigger offset>; I can't seem to find on documentation how to set the trigger price when using Triggered Trailing Stop as a parent order. Thanks Date Time Of Last Edit: 2017-07-30 11:41:07
[2017-07-30 20:34:42] |
We need some time to update the documentation for this.
[2017-08-01 06:11:15] |
We apologize for the delay. The documentation is now updated. You need to use Price2 for the trigger price: https://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#Price2 Price1 sets the Stop price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-01 13:27:23] |
Also if you wanted to use a Triggered Trailing Stop-Limit order you will need version 1592 or higher. There was a change required to support setting the trigger price in the case when this order type is used as the main order.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-01 14:30:32
[2017-08-01 14:00:00] |
Samuel - Posts: 8 |
Oh thanks, does it apply to Triggered Trailing Stop orders as well?
[2017-08-01 14:30:01] |
No, you do not have to update in the case of a Triggered Trailing Stop order.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-01 14:30:57
