Date/Time: Wed, 22 Jan 2025 23:11:56 +0000
how to replay with spreadsheet
View Count: 761
[2017-07-29 15:27:09] |
traderacademie - Posts: 38 |
Hi, I've added a Spreadsheet Study to a chart, and entered it with formulas. However, when I replay the chart, the spreadsheet is not updating at all. How can I replay the spreadsheet together with the charts? Rgds Will |
[2017-07-30 19:36:14] |
If you do not see on the Sheet that the Spreadsheet Study is referencing, the chart values as the chart is replaying, then you are looking at the wrong Sheet. There simply is nothing special to do. Make sure you have the correct sheet selected: Working with Spreadsheets: Difference Between Sheets and Spreadsheets If you still have a problem, we need to understand specifically what you are not seeing on the Sheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-30 19:37:58
[2017-07-31 07:37:28] |
Hi, Thanks, I figured it out. The problem was I was replaying multiple charts with the link number option, but forgot to link the chart with the spreadsheet attached to it. Rgds Will |
