Date/Time: Fri, 24 Jan 2025 14:40:55 +0000
unfinished auctions
View Count: 4547
[2017-07-29 03:36:44] |
Yamin2000 - Posts: 31 |
How do i make the unfinished auctions marked ? see picture https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=7841 |
[2017-07-29 06:06:04] |
nicktrader - Posts: 732 |
Hi Yamin, you need Study NumbersBars. Please take a look on my pic |
Unfinished Business in Study NumbersBars.png / V - Attached On 2017-07-29 06:04:03 UTC - Size: 61.62 KB - 1682 views |
[2017-07-29 13:37:43] |
You need to update to the latest release of Sierra Chart. And this Input with the Numbers Bars study supports this highlighting and extension lines: Numbers Bars: Highlight Nonzero Bid&Ask Volume at High/Low Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-27 16:51:47] |
User274676 - Posts: 38 |
Can this be done for Bar POC in Numbers Bars? To extend?
