Date/Time: Sun, 24 Nov 2024 00:04:16 +0000
How to apply saved spreadsheet to the chart?
View Count: 1376
[2013-09-01 18:47:25]
User14682 - Posts: 83
I developed a spreadsheet trading system and saved it. I am trying to upload the spreadsheet to a chart and run a back test and the spreadsheet wont take. Any help?
[2013-09-01 19:08:09]
Sawtooth - Posts: 4118
Add the correct spreadsheet study, and press Select next to the Spreadsheet Name field to choose your saved spreadsheet.
This won't have saved your spreadsheet settings. To do that, use the Save Single button in the Save Studies As Study Collection section, after you have given it a name and checked Prompt To Remove Existing Studies.
Date Time Of Last Edit: 2013-09-01 19:11:57
[2013-09-01 19:33:06]
When I try to add the spreadsheet from the studies tab the signals dont show up? when I retrieve the spreadsheet from the file tag it look perfect??
[2013-09-01 19:52:27]
Look at every Sheet# tab on the spreadsheet.
Sheet#'s correspond to chart #'s. If you added it to a chart # that is different than the one it was on when you built the formulas, you will be looking at a sheet without formulas.
[2013-09-01 19:58:05]
Right on thanks
[2013-09-04 03:56:43]
The instructions for what you want to do are in step 8 here:
https://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php#StepbystepInstructions
Date Time Of Last Edit: 2013-09-04 03:57:28
