Date/Time: Wed, 15 Jan 2025 13:01:13 +0000
Automatic Sizing
View Count: 924
[2017-07-28 20:25:56] |
User297539 - Posts: 55 |
After upgrading to version 1590 in the settings of "Customize Chart/Trade Dom Columns" can't uncheck the Automatic Sizing. Updated to version 1591 the problem persists.
28-07-2017 21-30-50.jpg / V - Attached On 2017-07-28 20:25:25 UTC - Size: 95.69 KB - 313 views |
[2017-07-28 20:41:07] |
Refer to the documentation here for how this works: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
