Date/Time: Wed, 15 Jan 2025 12:59:41 +0000
Scanning for stocks
View Count: 1339
[2017-07-28 20:08:40] |
User411363 - Posts: 4 |
Hi guys I'm pretty new with sierra charts. Im looking to up my game by doing market replays for small caps. I was wondering is there a way to scan for stocks while in replay mode in intraday. So for example if i went back to june 25 2017 and i scanned for stocks intraday that day, would sierra show me the stocks at that particular time or is it not possible for you guys yet.
[2017-07-28 22:41:07] |
Have a look at this functionality here: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-28 23:15:32] |
But isn't this only for alerts. I want to can intrday for all stocks and symbols. do you understand that point that im trying to say
[2017-07-29 13:52:47] |
It is not completely clear what you want to do. What do you mean by "all stocks and symbols". It would be best if you give us a very very specific example of what you want to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-29 15:24:03] |
so basically let's say i want to get better at trading stocks so that means i would do replays ok. But the problem is i dont know what plays to play. I tried looking for services that scan for historical gainers but there isn't one except for higher priced stocks. So i was just wondering is there a way to scan for intraday stocks while in replay mode. So that the stocks that show up will will be the gainers for that day
[2017-07-30 19:48:59] |
We have answered this here: Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
