Date/Time: Wed, 15 Jan 2025 12:48:03 +0000
Requesting another free trial..
View Count: 1202
[2017-07-28 19:05:21] |
robertcs68 - Posts: 1 |
Hello, I did a free trial about 2 years ago, and I'd like to take another look at your platform since you have have several updates since then. What are the steps needed to get another free trial? I am currently trading at Tradovate, so I don't need any data set up I don't think.. I think I can just get your free trial set up here, and then have Tradovate connect me with my data at Tradovate and then try it out that way. Let me know what I need to do. Thanks, Robert |
[2017-07-28 19:11:28] |
Sierra Chart - Max - Posts: 5778 |
1. Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". 2. Tradovate supports the CQG trading platform service. Refer to the CQG setup instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support |
