Date/Time: Wed, 15 Jan 2025 12:43:16 +0000
Advanced Decline Line
View Count: 530
[2017-07-28 17:19:08] |
Rino - Posts: 124 |
Hi, Can the Advanced Decline Line be set to start at 0 on a new day? I do not see that option on it. Thanks as always, |
[2017-07-28 20:03:45] |
You need to use this study instead to accomplish this: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
