Date/Time: Fri, 26 Jun 2026 18:43:22 +0000
ACSIL Drawings cannot be selected/moved in 1590
View Count: 1294
[2017-07-28 15:28:07]
onnb - Posts: 666
I have AddAsUserDrawnDrawing=1
In 1590, I cannot select or move lines on the chart.
In 1587 it works ok.
[2017-07-28 15:54:30]
There are no known changes which have been made which would cause this and we do not see a problem.
Use this test code for an example. We can select and move the Ray drawing added by this code, through the user interface just fine.
SCSFExport scsf_DrawingToolTest(SCStudyInterfaceRef sc)
  // Set configuration variables
  if (sc.SetDefaults)
    sc.GraphName = "Drawing Tool Test";
    sc.GraphRegion = 0;
    sc.FreeDLL = 0;
    sc.AutoLoop = 0;
    return;
  // Do data processing
  s_UseTool Tool;
  Tool.Clear(); // reset tool structure
  Tool.ChartNumber = sc.ChartNumber;
  Tool.AddAsUserDrawnDrawing = 1;
  // Draws a Ray (extending line) from the the low to the high over the last 10 bars.
  Tool.DrawingType = DRAWING_RAY;
  int &LineNumber = sc.GetPersistentInt(2);
  if(LineNumber != 0)
    Tool.LineNumber = LineNumber;
  // Set BarIndex to 10 bars from the end
  int BarIndex = sc.ArraySize - 10;
  BarIndex = max(BarIndex,0);
  Tool.BeginDateTime = sc.BaseDateTimeIn[BarIndex];
  Tool.EndDateTime = sc.BaseDateTimeIn[sc.ArraySize - 1];
  Tool.BeginValue = sc.Low[BarIndex];
  Tool.EndValue = sc.High[sc.ArraySize - 1];
  Tool.Region = 0;
  Tool.Color = RGB(0, 0, 255);
  Tool.AddMethod = UTAM_ADD_OR_ADJUST;
  sc.UseTool(Tool); // Here we make the function call to add the line
  LineNumber = Tool.LineNumber;//Remember line number which has been automatically set
  s_UseTool ChartDrawing;
  sc.GetUserDrawingByLineNumber(sc.ChartNumber, LineNumber, ChartDrawing);
Date Time Of Last Edit: 2017-07-28 15:55:00
[2017-07-28 17:10:39]
onnb - Posts: 666
Your example works - I can select the line.
Using the code below I cannot select the line.
  if (sc.SetDefaults)
    sc.GraphRegion = 0;
    sc.FreeDLL = 1;
    sc.AutoLoop = 0;
    return;
  s_UseTool Tool;
  Tool.Clear();
  Tool.DrawingType = DRAWING_HORIZONTALLINE;
  if (LineNumber != 0)
  Tool.Region = sc.GraphRegion;
[2017-07-28 18:33:29]
OK we think we know what the problem is. We will resolve this in the next release which we will have out today or tomorrow.
Date Time Of Last Edit: 2017-07-28 18:33:39
[2017-07-28 22:43:42]
This is now resolved in the latest revision of prerelease 1591.
