Date/Time: Wed, 15 Jan 2025 13:09:04 +0000
Customize DRAWSTYLE_CUSTOM_VALUE_AT_Y format ?
View Count: 794
[2017-07-28 14:28:01]
wwwingman - Posts: 185
Hi
I use DRAWSTYLE_CUSTOM_VALUE_AT_Y drawstyle and find it valuable for visual research.
However, The value drawn seem to be set by the scale values.
Is it possible to set it differently ?
( for ex, I want the value to be drawn as integers, no need to the decimal part... )
-- W
[2017-07-28 14:46:13]
This is not clear for us what you are asking about.
The study Scale is going to control where the values are drawn.
[2017-07-28 14:57:36]
The values are drawn at the proper price. But instead of drawing a value of 500.00 I would prefer to have 500. It seem to draw 500.00 because the scale format is set to two decimals... but I do not want to change the scale of the chart. I want to change the settings of the subgraph only...
-- W.
Date Time Of Last Edit: 2017-07-28 14:58:05
[2017-07-28 15:08:15]
You can set the Value Format for the study with sc.ValueFormat.
