Date/Time: Thu, 13 Feb 2025 03:58:20 +0000
Transparency level for color background indicator not working
View Count: 2785
[2017-07-28 11:52:27]
PATRICIA - Posts: 10
I am using the indicator color background based on alert and would like to change the opacity of the background color. I notice there is a transparency level fill box where I should be able to change the opacity but it does not change when I change this level. Is this something I can do with the color background indicator or not. Thanks in advance.
[2017-07-28 12:25:33]
The Background Draw Style does not support transparency. Why do you require transparency for that since it is already drawn in the background?
[2017-07-28 12:33:29]
I would like it to not appear so bright, using a different color doesn't really make a difference. I want it really to be in the background and not over powering the indicator area I am using the color background indicator on.
[2017-07-28 19:52:38]
So you are saying it is not in the background? Try changing the Study Display Order:
Chart Studies: Study Display Order
A very very strong disadvantage of transparency is that it significantly increases CPU usage. You really do not want to use transparency anyway.
Date Time Of Last Edit: 2017-07-28 19:53:08
[2017-07-31 10:01:53]
Yes it does appear in the background but I would like it to appear more transparent, I am assuming I can't do that with the color background indicator? It has a spot within the subgraph settings to change it but when the number is changed it does not change the transparency.
[2017-07-31 11:22:20]
We could add one, but it will not be very efficient.
[2017-07-31 12:00:50]
It would be great to have the option because it does distract from the price bars etc when background is full color. Of course whatever you decide.
[2017-07-31 14:24:55]
Yes, we will add this new Draw Style.
[2017-08-01 10:27:11]
Thank you VERY much, it is appreciated!
[2020-11-24 15:42:30]
User276793 - Posts: 55
Was this ever added? Using transparency on black background still does not work for me?
[2020-11-24 15:57:38]
Ackin - Posts: 1865
try change the Drawstyle to "BACKGROUND TRANSPARENT"
