Date/Time: Wed, 15 Jan 2025 12:59:34 +0000
ITA40 download fails
View Count: 1041
[2017-07-28 08:11:38] |
CarlRostron - Posts: 80 |
I am using the "SC Data - All Services", or some reason the Data for 'ITA40' symbol keeps failing. Any ideas why this might be at all please? All of my other downloads are working fine. Thanks |
Failed.png / V - Attached On 2017-07-28 08:10:47 UTC - Size: 46.16 KB - 233 views |
[2017-07-28 12:27:26] |
This symbol is no longer available.
[2017-07-28 13:43:25] |
Ok, I'll use IMIB.LS as an ETF to track instead. Thanks
