Date/Time: Fri, 02 Oct 2026 11:10:26 +0000
Disable trading on one DOM
View Count: 3022
| [2017-07-27 23:38:23] |
| Solaris24 - Posts: 1 |
Hi SC Support, Is there a way to disable trading on only one Trade DOM window? For example I have ES and NQ next to each other, but only trade the ES. I’d like to prevent accidentally submitting orders on the NQ DOM. I’ve tried removing the buy/sell order columns, but apparently you cannot. I’ve also looked at “Ignore Input” under the chart DOM settings, but they are global not chart-specific. Thanks, Felix |
| [2017-07-28 19:11:02] |
You just need to enable Order Confirmations through the M/Menu button on the attached Trade Window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-28 19:12:26
| [2017-07-28 19:12:08] |
Prior post has been updated.
| [2019-10-15 18:41:18] |
| Woodzy - Posts: 35 |
Is this still the only way to kind off lock certain DOMs? I tried Confirm New Orders in the M menu from Trade Window, but I can still place limit orders on DOM without any confirmation. I only want one DOM unlocked for trading, and 3 or 4 up for reference but locked to trading.
| [2019-10-15 21:53:24] |
This would mean you are enabling the Confirmations on the wrong Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Or just use a standard chart and enable this option to see the market data columns: Trade Menu: Show Market Data Columns (Trade menu) You would not be able to trade from a standard chart that is not in chart trade mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-10-24 21:38:16] |
| User76183 - Posts: 69 |
What I did. I customized DOM, detached it's window, created DOM's Control Bar (Customize Control Bar-find "Trading Locked"), so as to have own button "Trading Locked". By pushing this button I activate/deactivate trading through this DOM
| [2022-01-18 19:26:00] |
| User952036 - Posts: 16 |
A possibility is: Open the trade windows for the chart. Put an OCO order in with target and stop. Set the quantities for the OCO orders = 0 Close the trade windows for the chart. If you now click in the buy/ask column, this produces an error message: Trade Order Error - There is only one Attached Order and it is set to 'All OCO Groups'. Set it to another OCO Group to continue with order entry. | 2022-01-18 19:08:16.819 * However, no orders or trades are placed in the dom/market. |
Attachment Deleted. |
