Date/Time: Wed, 15 Jan 2025 12:52:01 +0000
hotkey processing
View Count: 1144
[2017-07-27 15:28:05]
cross - Posts: 70
My screenshot program stopped taking the shots on the hotkey.
On the other hand some windows default hotkeys has begun to work again.
Alt+PrintScreen was set to take and autosave a screenshot by Screenpresso but now when I am on the Sierra window it only copies the image onto the clipboard (default Windows behaviour). Or I set Win+Q to increase sound volume (by AutHotkey program) but now the same keypress brings up Cortana Search if Sierra window is in focus!?
I am using 1590 on Win 10. I appreciate any comments on this.
Thank you
[2017-07-27 16:04:46]
Not sure about this.
The only thing we can say is that Sierra Chart keyboard shortcuts are controlled through Global Settings >> Customize Keyboard Shortcuts.
[2017-07-28 12:25:44]
Marmany - Posts: 307
For info W10 applied an update this morning. This affected the top left row of keys on my Logitech K330 keyboard - they were not picking up the custom commands.
Contacted Logitech, followed their suggestions without success.
By trial and error disconnected keyboard, re-booted with an older keyboard, re-loaded SetPoint and found all keys worked OK. On switching back to K330 all keys continue to work in correct manner.
No idea why this worked, but problem solved.
[2017-07-28 13:10:20]
cross - Posts: 70
Hey Marmany, your problem description match mine. I was not sure about the Win10 Update part but now I think that could be the problem.
I'll follow your procedure.
Thanks Marmany!
