Date/Time: Wed, 15 Jan 2025 12:39:49 +0000
Windiw error 126
View Count: 933
[2017-07-27 14:00:01] |
User407575 - Posts: 13 |
Hi, I am recieving the following error: Error loading Custom Studies DLL: C:\SierraChart\SierraChartTransActMA\Data\es.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 10:03:45 * What should I do? Thanks, Fatima |
[2017-07-27 14:11:24] |
Are you trying to use a particular custom study? If so, what is the name of it?
[2017-07-27 14:25:14] |
Yes, I both indicators from Rockwell trading , I copy the files in C:\SierraChart\SierraChartTransActMA\Data file. When I open the chartbook. I got this error and the indicators are not working. Thanks Fatima |
[2017-07-27 15:18:38] |
Additionally, I am working with those indicators for more than 7 months and they were working well. Except last Monday, when I downloaded the last version of the chart Software. Everything was messed up.
[2017-07-27 16:06:10] |
OK, then this is a very old Chartbook that has apparently not been saved for a long time. Was this Chartbook provided through your broker? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 16:09:04] |
There is a Rockwell Chartbook on this page that you can use: Additional Files (Study Collections, Spreadsheets, Chartbooks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 16:42:35] |
Hi, Thank you so much. Now it is working well. I have still one small issue. I used to watch 6 markets. the indicators are installed in all of them except CL. How can I add one more chart with CLU7 symbol and Rockwell indicators. Thank you Fatima |
[2017-07-27 16:48:57] |
I am sharing with you the indicators zip folder Thank you |
Private File |
[2017-07-27 16:51:40] |
I used to use Rockwell_incl_GC_CL.cht and my coach shared with me 2017 updated file. This one has all the symbols but not working |
2017 Update - Rockwell Trading.cht - Attached On 2017-07-27 16:51:10 UTC - Size: 721.99 KB - 351 views |
[2017-07-27 17:47:56] |
We need to contact the broker about this. That Chartbook is referencing an invalid studies filename.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-27 17:53:40
[2017-07-27 19:11:27] |
My broker is Infinity futures I bought indicators from Rockwell trading. You will contact them or I should do some action? Thank you |
[2017-07-27 19:39:11] |
We already contacted your broker about this.
