Date/Time: Wed, 15 Jan 2025 12:55:01 +0000
Spreadsheet Calculation Columns Increase
View Count: 946
[2017-07-27 12:01:38] |
User787778 - Posts: 142 |
Understanding the increased demands on computing power, is it possible to increase the number of spreadsheet calculation columns from 60 to 90? Thanks in advance. |
[2017-07-27 12:06:43] |
No. Use an additional Spreadsheet Study instead. This cannot be increased because it depends upon the number of Subgraphs in a study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-31 18:47:58] |
What is the most efficient way of consolidating multiple spreadsheets from the same chart into a "Master" spreadsheet? Study Overlay? Thanks in advance. |
[2017-07-31 20:50:22] |
You could add multiple Spreadsheet Study studies to the chart. You then could use the Spreadsheet System/Alert or Spreadsheet System for Trading study and then you will see the Spreadsheet Study columns outputted to the study columns.
