Date/Time: Wed, 15 Jan 2025 12:57:33 +0000
SierraChart Real-Time feed
View Count: 1002
[2017-07-26 21:39:26] |
AlexPereira - Posts: 197 |
Hi, I saw that on your services page it says: If you are looking for a high quality futures and stock data feed for Sierra Chart, then this is an excellent choice. For example, if you are using the Numbers Bars study, this is one of the very best data feeds to use.
I have numbers bar package, would I have any advantage for example trading EURUSD forex symbol on my forex broker with your feed service, than from my brokers feed ? Any advantage in terms of numbers bar and market depth quality ? Thanks |
[2017-07-26 22:10:46] |
No. If you are referring to LMAX, that is already a good data feed.
[2017-07-27 12:31:23] |
Thanks very much for the answer. Also, is FXCM feed good for Numbers Bar and ask vs bid volume analysis ? |
[2017-07-27 13:11:42] |
Yes to the extent that bid/ask only symbols would be. And there are not any other data feeds we have available for the cash Forex and CFD markets anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-27 13:12:58
