Date/Time: Wed, 15 Jan 2025 12:49:58 +0000
Connect to Data Feed
View Count: 898
[2017-07-25 20:47:10]
User455902 - Posts: 16
Got a message yesterday that SSD was full. Did a disk cleanup,and moved some files to HDD. Apparently, moved the wrong file(s), because I couldn't load charts. Got username and password to log in(OK), but not connected to data feed. Went to Data/Trade Services Settings, and server, username, and password were blank. Filled in what I thought were the correct Sierra/CQG fix username and password, but got a log file that said CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2017-07-25 15:02:54. tia for help.
[2017-07-25 21:44:36]
You will need to find out from your broker what the Username and Password are. Here is the relevant documentation for this:
CQG Trading Platform Service: Common Error Messages
Also go through the step-by-step instructions here to make sure you have the correct Server setting:
CQG Trading Platform Service: Setup Instructions
Date Time Of Last Edit: 2017-07-25 21:47:23
