Date/Time: Wed, 15 Jan 2025 12:45:24 +0000
Occurring error during installation
View Count: 769
[2017-07-25 20:06:26] |
User407575 - Posts: 13 |
Hi, I had problem yesterday with a warning error. I unistall Sierra and trying now to install it. I received the following message. Thank you Fatima |
Private File |
[2017-07-25 21:08:29] |
This log is from the TransAct software. You will need to contact TransAct support for help with this. Contact your broker and have them put you in contact with them. You can download Sierra Chart from this page: Software Download In the case of TransAct you will need to install it into C:\SierraChart\SierraChartTransActMA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
