Date/Time: Wed, 15 Jan 2025 12:38:03 +0000
Volume At Price Threshold Alert v2 - Display Problem in Version 1589
View Count: 881
[2017-07-25 18:16:25] |
cmet - Posts: 580 |
Using this with "Square offset left body" and "offset right body". These squares appear very large after the update to 1589 even though the size is set to 2. Changing the setting to 1 doesn't resize them. ??? |
[2017-07-26 12:35:35] |
We will resolve this.
