Date/Time: Wed, 15 Jan 2025 12:37:18 +0000
Custom Study
View Count: 1113
[2017-07-25 15:14:09] |
User14683 - Posts: 34 |
Hi I am subscribed to The Trader Institute (TTI) and use the TTI Volume Profile. I upgraded to SC 1589 and am not able to Add this Custom Study. Attached please see the Message Log SC 1589 is working fine (TTI Volume Profile) on my other computer. |
Private File |
[2017-07-25 15:38:16] |
These are the relevant messages: Error loading C:\SierraChart6\Data\tti_alert.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 10:59:03 * Check with developer of the studies and find out if there is any other dependent DLL file required. If they are using Visual C++, then they need to use static linking to the runtime libraries.DLL likely has a missing dependency file. | 2017-07-25 10:59:03 * Error loading C:\SierraChart6\Data\tti_volume_profile.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 10:59:03 * DLL likely has a missing dependency file. | 2017-07-25 10:59:03 * Error loading C:\SierraChart6\Data\tti_alert.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 11:00:05 * DLL likely has a missing dependency file. | 2017-07-25 11:00:05 * Error loading C:\SierraChart6\Data\tti_volume_profile.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 11:00:05 * DLL likely has a missing dependency file. | 2017-07-25 11:00:05 * Error loading C:\SierraChart6\Data\tti_alert.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 11:00:19 * DLL likely has a missing dependency file. | 2017-07-25 11:00:19 * Error loading C:\SierraChart6\Data\tti_volume_profile.dll. Windows error code 126: The specified module could not be found. | 2017-07-25 11:00:19 * DLL likely has a missing dependency file. | 2017-07-25 11:00:19 * Refer to step 11 here about this: https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php#ConfigureProject Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-25 16:24:44
