Date/Time: Wed, 15 Jan 2025 13:01:48 +0000
Spreadsheet - Blank Columns before First Study
View Count: 911
[2017-07-25 06:20:13] |
User787778 - Posts: 142 |
Using these columns to perform calculations in a Spreadsheet System for Trading appear to work without any problems. Other than the need to copy the formula down manually, are there any other issues that I need to take into account when using these columns? Thanks in advance. |
[2017-07-25 13:16:17] |
No, nothing else.
[2017-07-25 16:20:42] |
Sawtooth - Posts: 4151 |
If you increase/decrease the Number Of Formula Columns, values in those columns will be overwritten.
[2017-07-25 16:23:35] |
Thank you Tom
