Date/Time: Wed, 15 Jan 2025 13:10:18 +0000
subgrapg drawing
View Count: 672
[2017-07-25 00:37:10] |
jizzary - Posts: 177 |
I see that if a subgraph values are all ZERO .. the subgraph is not drawn Is there a way to enforce the sungraph be drawn though all its values are ZERO ? Date Time Of Last Edit: 2017-07-25 12:04:10
[2017-07-30 10:50:41] |
any comment please .... tnx
Date Time Of Last Edit: 2017-07-30 10:50:53
[2017-07-30 19:10:43] |
You have already wasted a lot of our time and have abused support enough. We have no idea why this question is being asked when it is so clearly documented on the ACSIL Subgraphs page. You complain a lot about documentation over small little details. And the Sierra Chart documentation overall is very very good. Although we cannot always cover every single detail that we did not think of. Yet, you cannot even find this in the documentation. We are small business. Take for example the Chicago Mercantile exchange. A multibillion-dollar operation. Do you know their technical market data documentation in many areas is substandard and the user has to figure things out by looking at template files and things like that. If you were to speak to the CME, in the way that you do to us, they would just ignore you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-30 19:14:35
[2017-07-30 20:21:56] |
SCSubgraphRef my_sg = sc.Subgraph[0]; SetDefaults block my_sg.Name = "xxxxx"; my_sg.DrawStyle = DRAWSTYLE_BAR; my_sg.PrimaryColor = RGB(166, 123, 11); my_sg.LineWidth = 4; my_sg.DrawZeros = 1; on every bar my_sg.Data[sc.Index] = 0; but: no draw appears ... what have I done wrong ? pls assist. tnx ------------------------------- You need to understand that I'm asking if I can't find a solution by myself. I'm trying to waste your time but there is a limit to the time I can put on tries. see my code above ? it doesn't draw zeros. can't figure out why this may be known only to whom developed the platform. I hope I made myself clear. tnx for understanding Date Time Of Last Edit: 2017-07-30 21:35:00
