Date/Time: Wed, 15 Jan 2025 16:06:36 +0000
CTS T4 Advanced Low Cost Connection Model
View Count: 743
[2017-07-24 16:11:42] |
User841161 - Posts: 229 |
A broker or clearing firm has to be used to use CTS. So can it be just a broker or just a clearing firm, that supports CTS in order to use CTS. Are Wedbush and Dorman the only clearing firms that support CTS?
[2017-07-24 17:11:42] |
So can it be just a broker or just a clearing firm, that supports CTS in order to use CTS. Yes.There is also AMP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-24 17:48:03] |
Sierra Chart - Max - Posts: 5778 |
From User: Straits Financial list that it supports CTS T4, they are not on your list. Do they work with Sierra Charts and CTS T4.
Sierra Chart Support |
[2017-07-24 18:13:45] |
Yes if they support CTS T4, then they will be supported by Sierra Chart. There may be an approval that will be required by them, but we would not expect that to be a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
