Date/Time: Wed, 15 Jan 2025 16:08:59 +0000
The additional hundred's of a second
View Count: 597
[2017-07-24 13:10:19] |
User432504 - Posts: 73 |
SC: Is there a way to turn off the display of the hundred's of a second on the charts. For example, I see where to set the time to month, day, hour , minute and second but I don't see a box to turn off the additional break down of a second. Right now I see, as an example, 07-24 09:07:59:018 I would like to take off the "018" part of the time display. Is that possible? Thanks in advance. |
[2017-07-24 16:26:24] |
This cannot be removed.
