Date/Time: Wed, 15 Jan 2025 16:14:48 +0000
ACSIL - VolumeAtPriceForBars
View Count: 1081
[2017-07-24 04:20:55] |
ejtrader - Posts: 688 |
SC Team - In one of the recent versions - you seem to have made few changes to c_VAPContainer class. c_VAPContainer::GetNextHigherVAPElement() - No changes to this and same as before c_VAPContainer::GetNextLowerVAPElement() - You seem to have got rid of this function. Is there any substitute function to be used for this? thanks |
[2017-07-24 18:14:31] |
We need to check on this and get back to you.
[2017-07-24 18:39:42] |
Jeffrey - Posts: 2195 |
c_VAPContainer::GetNextHigherVAPElement was recently modified for more efficient performance. This made c_VAPContainer::GetNextLowerVAPElement significantly less efficient than GetNextHigherVAPElement, so it was removed. Most code accessing the data in a c_VAPContainer should use GetNextHigherVAPElement. However, if c_VAPContainer::GetNextLowerVAPElement is vital to your work, reply here and we can add a similar function back to VAPContainer.
[2017-07-24 19:05:14] |
Jeffrey - Yes - I do use the function - GetNextLowerVAPElement() and would be nice to have equivalent efficient function added back. thanks Date Time Of Last Edit: 2017-07-24 19:06:40
[2017-07-24 19:08:27] |
We will work to get GetNextLowerVAPElement() included again for the next release.
