Date/Time: Wed, 15 Jan 2025 15:57:22 +0000
Windows Error Code 5 when Updating Version
View Count: 1109
[2017-07-24 00:51:35]
MsJackson - Posts: 27
Log has been sent
[2017-07-24 03:18:23]
This is the relevant message:
Error moving C:\SierraChart\DownloadedInstallationFiles\SierraChart.exe file to the folder C:\SierraChart\. Windows error code 5: Access is denied.
Disable any security software running on your computer.
And make sure Sierra Chart is not running during the installation process and try again.
[2017-07-24 19:39:02]
We implemented a workaround for this kind of issue. If you still are getting the error try updating again following these instructions:
[2017-07-24 20:00:48]
I was able to update versions by changing the security setting on my C Drive to allow full control for users. I believe this was part of a recent update for Windows 10. Thanks
