Date/Time: Wed, 15 Jan 2025 16:24:59 +0000
ASCIL --> drawing tool - collection of lines to act as one
View Count: 758
[2017-07-23 20:53:48]
JohnR - User831573 - Posts: 307
I have taken the example supplied in ASC_Source to draw multiple lines in a tool instance. I have been able to add another line as well as use a button to get mouse clicks on multiple locations (3 to be specific). I would now like to know how to have all of the lines I created in this instance of "Tool" move as one tool. Example the pitchfork. You select 3 points and then when you move it, all lines move / adjust as one tool instance. If it would be possible to see what the code looks like for the pitchfork tool, that would be of great help, I think. I am able to let the user move the lines / markers around, but only individually one line at a time.
Thanks in advance for your time to reply.
John R.
Date Time Of Last Edit: 2017-07-23 20:54:41
[2017-07-23 22:03:30]
There is no example for this. This is something that you would have to implement. This is not like some kind of built-in concept.
You would have to modify all three Tool drawings individually.
