Date/Time: Wed, 15 Jan 2025 12:51:12 +0000
Accessing functions from another chart
View Count: 924
[2017-07-23 18:17:49] |
User735389 - Posts: 189 |
I understand that I can use GetChartBaseData and GetChartDateTimeArray to get most of the necessary price data from another chart. Is there a way to still use functions like GetHighest(), GetContainingIndexForSCDateTime(), etc... on that data? It seems like I should be able to get a "Chart" object that contains the base chart information, along with its BaseData, and use a lot of standard functions to access/manipulate that data. Am i missing something?
[2017-07-27 01:14:05] |
The sc.GetContainingIndexForSCDateTime function can reference any other chart through the Chart Number parameter. sc.GetHighest can also be used with any SCFloatArray. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
