Date/Time: Wed, 15 Jan 2025 13:06:37 +0000
Replay Chart - Lag
View Count: 1339
[2017-07-22 02:20:18] |
User839162 - Posts: 87 |
I noticed tonight when I tried to go over today's action with "Replay Chart" that it was extremely laggy. I don't remember it being like this the last time I used it. Please take a look at the attached .gif. Thanks |
2017-07-21_21-09-40.gif / V - Attached On 2017-07-22 02:19:07 UTC - Size: 731.22 KB - 402 views |
[2017-07-25 22:18:19] |
Any update on this? I would really like to use this feature, but it's useless in it's current state. I'm attaching another .gif to show how laggy it is. I'm on the most current pre-release 1589. Thanks |
Attachment Deleted. Private File |
[2017-07-25 22:39:46] |
We do not understand what you are trying to show. There is no problem with the replay functionality. If it does not meet your requirements then do not use it. We will not get involved with this because there is no problem whatsoever with replay. Maybe this information may be helpful: Replaying Charts: Historical Intraday Data Record Timeframe Effect on Replays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-25 22:41:59
[2017-07-26 02:40:44] |
If the lag you are referring to is within a second, we definitely cannot help with that, but it might be related to how time stamping is done and that will be improved upon in the next 2 to 3 months. If the market depth data is out of sync with the last trade prices, then we may or may not be able to help with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-26 06:41:31] |
Merlin - Posts: 83 |
I notice you're using "Standard Replay" mode. You might want to try "Calculate at every tick/trade" mode and see if that works better for your purposes. I find that mode works better for me. I set the processing step to 1 second. Contrary to the warning, I've had no problem at all with high CPU usage, even though my chartbook has 10 charts, with many studies on each chart. Merlin |
