Date/Time: Wed, 15 Jan 2025 16:16:09 +0000
How to set the font size of the numbers in the VxP study
View Count: 800
[2017-07-22 01:56:14]
User432504 - Posts: 73
SC:
How do I change the font size of the numbers that display in each row of the VxP study when display volume in bar (In:46) is set to bid volume x ask volume?
I would like to make them bigger.
I tested selecting the use larger number display formatting set to Yes and nothing changed?
Thanks in advance.
Date Time Of Last Edit: 2017-07-22 01:56:40
[2017-07-23 14:28:59]
This is explained here in the description for the related Input:
Volume By Price Study: Display Volume in Bars
[2017-07-23 15:00:06]
SC:
That doesn't work. When I go to SG7, the draw style is set to Visible, the line style is set to Solid and the default width is set to 0. If I change the width to 2, for example, and then click apply, your software makes no change and instead resets the width back to 0. What did I do wrong?
[2017-07-24 02:00:08]
Do not use a small size of 2. Use something more sensible. 2 will go back to 0.
You need to use something more like 10 or 12. The minimum is 5 which is extremely tiny and barely visible.
