Date/Time: Fri, 31 Jan 2025 16:43:17 +0000
[User Discussion] - Tom DeMark indicators
View Count: 10179
[2013-08-30 21:28:40]
kona808 - Posts: 12
There was a user discussion thread on the old support board re Tom DeMark (TD Sequential) indicators. I have had some progress here (3rd party developer)- if there are others interested in this indicator feel free to reply here as I am looking to share development costs (not a lot) with one or two interested traders/parties.
SC - is there any way to flag this to the others who I was conversing with on the old support board/user discussion?
thanks
[2013-09-03 17:29:21]
We will get back to you on this.
[2013-09-03 23:22:40]
Sierra Chart - Max - Posts: 5780
For reference, this is the link to the old thread:
http://www.sierrachart.com/supportboard/showthread.php?t=18833
Sierra Chart Support
Date Time Of Last Edit: 2013-09-04 03:15:14
[2013-09-04 03:53:50]
Could you let us know how much the cost is.
[2013-09-04 03:58:47]
kona808 - Posts: 12
Approximately $1000.
Although I will be checking a sample of the code shortly to ensure the rules/strategy is correct.
[2013-09-07 02:34:32]
We have posted a link to this new thread in the old thread. So anyone who was subscribed to the old thread will have received an email notification and now can see this new thread.
We wonder who is doing the development? If you could let us know.
[2014-10-06 10:52:42]
moonmist - Posts: 127
Any new development on the TD Sequential indicator ? Someone has mentioned it on Elite Trader recently.
http://www.elitetrader.com/et/index.php?threads/tom-demark-sequential-indicator.118030/page-11#post-4033674
Date Time Of Last Edit: 2014-10-06 10:54:01
[2016-11-24 12:05:45]
michelh - Posts: 159
I have paid for the development of TD Setup, TD Sequential/Countdown and TD Combo and TD REI (see screenshot).
Red horizontal lines are resistance for TD setup
Green horizontal lines are support for TD Setup
Blue Numbers are setup
Green numbers are sequential
Yellow Numbers are Combo
13s sequential or combo are accented with an arrow above the 13.
The coding is by the book. However, the recycle criteria are NOT coded. So EVERY SETUP is shown and if it recycles, you will have to mentally ignore the sequential and combo from a recycled setup.
I have attached the daily chart of gold. As you can see:
there was a sequential countdown on the test of the top.
setups frequently mark a pause in the trend
corrections frequently terminate on setup support/resistance levels.
As I said, the only drawback with this code is that the recycle criteria are not coded - so you will have to think if you get 2 setups in the same direction as to which one is the valid one.
If this is of interest to you and you want to offset a portion of my cost of development, msg me.
Date Time Of Last Edit: 2018-04-28 01:00:18
imageGC-201612-NYMEX Daily #21 2016-11-24 06_58_32.977.png / V - Attached On 2016-11-24 12:01:24 UTC - Size: 128.27 KB - 1617 views
[2016-11-28 12:55:35]
So to answer any questions about the control panel and inputs, see the attached images.
The first chart shows 3 consecutive setups.
The second image shows the indicator control panels.
In this case, the active setup is the most recent one.
So by changing the indicator setting to cancel countdown and combo when a new setup is required, you can effectively recycle the previous setups by getting it to ignore the old setups and just focus on the current setup. The 3rd image isolates the current active setup without the numbers of TD combo and countdown from previous setups cluttering the screen.
So it is easy to recycle by changing indicator settings. It just isn't coded so will need to think about it.
Date Time Of Last Edit: 2017-10-28 23:34:29
imageGC-201612-NYMEX Daily #21 2016-11-28 07_41_54.290.png / V - Attached On 2016-11-28 12:51:24 UTC - Size: 133.08 KB - 1249 views
imageGC-201612-NYMEX Daily #21 2016-11-28 07_46_31.856.png / V - Attached On 2016-11-28 12:51:45 UTC - Size: 117.09 KB - 906 views
imagecontrol panel.jpg / V - Attached On 2016-11-28 12:52:15 UTC - Size: 1.4 MB - 1089 views
[2017-02-08 22:25:30]
Usermb - Posts: 126
Are there any plans to add a TD Sequential study to Sierra?
[2017-04-26 17:14:15]
Cmopcap - Posts: 12
Hi there
I have come across this post as I am after the sequential 9 indicator by TD.
I am a very long term user of Sierra Charts and I was wondering if this has been implemented please ?
Many thanks
[2017-11-22 14:35:22]
User871436 - Posts: 5
+1 on this, please. Would be greatly appreciated!
[2018-11-18 10:03:33]
User651753 - Posts: 77
Any update ? would like to know the current price for the indicator
[2018-11-18 19:11:45]
User833285 - Posts: 4
While I would like to express my overall satisfaction with your great software I would also very appreciate an integration of that indicator.
[2019-02-14 11:25:24]
User964132 - Posts: 93
Any update on the sequential 9 indicator by TD? Would be highly appreciated!
[2019-02-14 11:45:04]
I tried the cpp file from the old thread, but I got all kinds of errors, I guess it does not work for the 64-bit Sierra charts.. Could anybody change this? THANKS!
[2019-05-20 12:36:35]
User382312 - Posts: 4
Hi michelh, I'm Interested in the Demark Sequential you have for Sierra
I've sent you a permission request to DM you , if you could accept that then I can Direct Message you (I can't send you a message until you accept my request)
