Date/Time: Tue, 04 Nov 2025 14:58:03 +0000
Remote chart?
View Count: 2723
|   [2013-04-03 14:30:58]     |
| SgtJ - Posts: 154 |
                In the recent betas how do you open a remote chart? The option under the file menu is gone, browsing to remote folders doesn't work either. Don't see anything under "what's new"
|   [2013-04-03 14:36:53]     |
| FGBL07 - Posts: 19 |
                It's in the "Find Symbol" dialogue: there is a drop-down box at the top to select the instance you want the symbol to open from.
|   [2013-04-03 14:51:02]     |
| SgtJ - Posts: 154 |
                Thnks for your help.
|   [2013-04-03 16:21:42]     |
                Please see: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
