Date/Time: Wed, 15 Jan 2025 16:13:48 +0000
sc.AddLineUntilFutureIntersection() no longer displays labels since 1584
View Count: 742
[2017-07-21 18:12:25]
binaryduke - Posts: 373
Hi Sierra Chart
screenshot 1 (VirtualBox_Windows SC_21_07_2017_19_02_15.png):
chart in 1580 using the built in Extend Close Until Future Intersection study (thick red line on chart) and a custom study that also uses sc.AddLineUntilFutureIntersection() - the label applied to this study is 'TS'
screenshot 2 (VirtualBox_Windows SC_21_07_2017_19_04_50.png ):
same chart in 1587 - you will see that no labels appear - the study settings and chartbook are the same
screenshot 3 (VirtualBox_Windows SC_21_07_2017_19_05_23.png):
study settings for Extend Close Until Future Intersection showing that display labels are enabled and the label is set to 'C'. One would expect to see a 'C' on the thick red line to the right of the study settings window
The behaviour has changed since 1580. I think 1584 introduced this change/bug. Please can you check at your end and advise. I'm confident this is not a custom study coding issue as your own Extend Close Until Future Intersection study is also affected.
Images are attached due to updating the software between screenshots in order to provide a flow to this case. Appreciate this is not your favoured image upload method but would appreciate your understanding on this one.
Lee.
Date Time Of Last Edit: 2017-07-21 18:13:26
Private File
Private File
Private File
[2017-07-21 23:59:39]
This will be resolved in the next release.
