Date/Time: Wed, 15 Jan 2025 12:42:17 +0000
question on vbp visable bars
View Count: 760
[2017-07-21 13:19:40] |
zippyzip - Posts: 293 |
hey guys , i was wondering why when i use vbp visible bars that i get these big spiking bars on the vbp , its set to ask-bid and as you can see it will plot huge bar with just imbalance of 1 , thanks
Private File |
[2017-07-24 13:30:42] |
any word on this , see even on dom there are small imbalances and there extending all the way into other column
Private File |
[2017-07-24 15:25:17] |
We will look this over.
[2017-07-25 04:42:24] |
We do not know how to reproduce this. Follow the instructions here to provide that single chart containing that Volume by Price study which will show this: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-25 04:42:43
[2017-07-25 11:54:03] |
here ya go , you will see on the smaller imbalances the profile extends very far , thanks for looking at this for me
Private File |
[2017-07-30 19:56:59] |
You are using a bid and ask coloring method setting which is not compatible with the Volume Bar Calculation Method you have chosen. In the latest release, this is automatically changed for you to None. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-30 19:57:23
