Date/Time: Wed, 15 Jan 2025 16:19:45 +0000
Futures Spread Symbols for CFE / CBOE Volatility futures on Interactive Brokers
View Count: 1119
[2017-07-21 04:06:26] |
User32628 - Posts: 15 |
I can't find the symbol format for these symbols in either the site documentation or under the Find Symbols menu item. I can find the format for legs (Vix-20170816-cfe-usd-1000 works for Aug 16 Vix futures) but not for spreads. For one example, VIX Aug 16 / Sept 20 futures on CFE.
[2017-07-21 05:02:54] |
Interactive Brokers spreads are not supported from Sierra Chart.
