Date/Time: Wed, 15 Jan 2025 16:02:45 +0000
IsLimitOrder of the s_SCTradeOrder structure
View Count: 620
[2017-07-20 14:52:50] |
User203925 - Posts: 40 |
I am trying to understand OrderDetails.IsLimitOrder which is part of the s_SCTradeOrder structure. Are there any coding examples? If not can you explain the functionality of this? I am trying to identify manually place limit orders on the DOM and pull the price of the limit order.
[2017-07-20 16:07:51] |
This checks the order type and returns true if it is a Limit order or a Market if Touched order. There is no need for a code example. It is simple and straightforward to use. You can also see the source code for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-20 16:08:11
