Date/Time: Sun, 19 Jan 2025 00:09:57 +0000
Study/Price Overlay and TPO
View Count: 1599
[2017-07-20 12:37:53] |
RonW - Posts: 105 |
Can I use Study/Price Overlay to copy the Point of Control Extension lines from a TPO Study to another chart? I've tried and it's not working for me. RLW |
[2017-07-20 13:13:01] |
This can only be used with the TPO Value Area Lines study, and not the TPO Profile Chart study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-20 13:13:11
[2018-03-09 21:04:57] |
User642139 - Posts: 20 |
I have an chart with VbP on it. I overlay the point of control from this VbP onto another chart without a problem. When I then add TPO study onto the original chart the overlay that was working correctly no longer works. I am wanting to have a TPO chart which also has a volume POC which I can overlay the volume POC onto another chart. It seems for some reason this is not possible. Is that correct?
[2018-03-12 19:51:53] |
Yes this is not possible and the documentation does explain this. You need to use a separate chart for the source study and do not put a TPO Profile Chart study on it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-12 19:52:40
