Date/Time: Thu, 26 Nov 2026 19:11:56 +0000
ACSIL function for Log10
View Count: 1212
| [2017-07-19 21:51:08] |
| Neo - Posts: 198 |
Can you add an ACSIL function for Log10 eg /* log10 example */ #include <stdio.h> /* printf */ #include <math.h> /* log10 */ int main () { double param, result; param = 1000.0; result = log10 (param); printf ("log10(%f) = %f\n", param, result ); return 0; } |
| [2017-07-19 22:09:12] |
It already exists in the C++ language. Just go ahead and use it.
| [2017-07-19 23:27:03] |
| Neo - Posts: 198 |
OK. If for example, there was an ACSIL function for Log10 Then in terms of SC study implementation, what would be more efficient- calling Log10 as an ACSIL function, or calling from math.h? |
| [2017-07-19 23:40:59] |
It would not make any difference.
