Date/Time: Wed, 15 Jan 2025 16:25:36 +0000
Order Entry Price Offset on Automated Trading Spreadsheet
View Count: 2448
[2017-07-19 19:34:12] |
John M - Posts: 171 |
I have a Trading Spreadsheet with Automated Buy/Sell entries working. Currently I am using a simple Market order to execute the trade entry with the automation. I would like to have the trade price entry set with an offset from the Bid/Ask. Example: Trade signal fires on Sell, Mkt order hits the Bid. I want the automated Order Entry to be 2 ticks above the Bid. How do I accomplish that? Thank you. |
[2017-07-19 21:38:46] |
I think I found it under Special Spreadsheet Trading Inputs on the Spreadsheet. Will see if this takes care of it, it should. Thank you |
[2017-07-19 22:02:07] |
You need to use Limit orders and set the order price. Refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
