Date/Time: Wed, 15 Jan 2025 16:15:05 +0000
sc.StdDeviation function
View Count: 905
[2017-07-19 19:02:59] |
rhovega - Posts: 279 |
Where can I find the code for the sc.StdDeviation ACSIL function? I opened all files in the ACS_Source folder and searched in them but could not find it. Thanks. |
[2017-07-20 13:39:08] |
It is in /ACS_Source/SCStudyFunctions.cpp void GetStandardDeviation(SCFloatArrayRef In, float& Out, int StartIndex, int Length) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-20 13:39:39
