Date/Time: Wed, 15 Jan 2025 15:55:34 +0000
Numbers Bar Alert?
View Count: 841
[2017-07-19 15:01:20] |
RonW - Posts: 105 |
I am using Numbers Bars displaying only total volume. I want to use Color Bar on Alert (or Color Background). Is there Alert Syntax for "If the Point of Control volume is greater than 500 contracts?" Thanks. |
[2017-07-19 15:19:03] |
No. The closest available is this study: Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
