Date/Time: Wed, 15 Jan 2025 13:01:15 +0000
Trading: Triggered Step Trailing Stop order and Move to breakeven
View Count: 1439
[2017-07-19 10:19:53]
AlexPereira - Posts: 197
Thank you for SierraChart, could I ask if there is currently a way to know or show, the prices for "move to breakeven" and "trigger to start trailing" ?
If using these two features of trading, could a line or mark be showed around the price that when reached, the stop would change to breakeven and also a line or mark around the price that will make the trailing stop start ?
Is there a way to see this on any log ? ( I saw that it is possible to see the offset and step of the orders in the activity log )
I am asking because I just had Triggered Step Trailing Stop order with breakeven, and the trailing started although it price never reached the amount of ticks it had to ( I had it set to 400 ticks, it started around 320 ticks ).
Probably Sierra Chart is doing the proper thing and I am doing something wrong somewhere, so it would be great to have the price displayed in some log or even a line or marker on the chart at what price the automatation will kick in.
Thanks !
[2017-07-20 07:44:08]
We can display this information on the Order Line using an option. We will do that.
[2017-07-28 11:05:22]
Thank you very much on doing this on the latest versions.
It has the info i need ( the trailing stop continues as it is triggered ).
Could I ask only to put a separator character between the number and the last text ? Right now is something like : TrailTrig: 12345Open ( a separator character between the number and the Open ).
Thank you very much !
[2017-07-28 16:52:35]
We will fix this. We had thought this was already the case.
Date Time Of Last Edit: 2017-07-28 16:59:11
