Date/Time: Wed, 15 Jan 2025 12:48:32 +0000
Large Volume Trade Indicator- Source code
View Count: 1885
[2017-07-18 22:56:08] |
Neo - Posts: 198 |
I can't locate the source code for the "Large Volume Trade Indicator". I have followed the documentation- https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Where can I find it? |
[2017-07-19 02:13:47] |
The source code is not available for this study. It consists of many internal parts and it would not be in any usable format. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-19 03:34:31] |
Neo - Posts: 198 |
Can you provide the source code for the algorithm you have used for the median(midpoint) normalization? I'm not interested in any other parts of the study.
[2017-07-20 00:19:03] |
Neo - Posts: 198 |
Is there anything you can provide me with here? I'm trying to create a generic study for Normalization. So I want to test out different normalization/ scaling/ ranking methods. |
[2017-08-12 13:01:02] |
Would be best that we document this more clearly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-14 20:28:15] |
Neo - Posts: 198 |
Ok. In the meantime, I created a percentile ranking algorithm. It's quite useful. |
