Date/Time: Wed, 15 Jan 2025 16:02:30 +0000
Persistant Variables
View Count: 792
[2017-07-18 15:56:16]
jizzary - Posts: 177
from dicumentation : each data type supports 5000 entries
1. this means that KEY valid range is 0..4999 - is that right ? or KEY expected to be 1..5000 ?
2. is there anyway my study can control that size ? thus decrease the value to be a lower one ?
tnx
[2017-07-18 21:28:32]
1. The key can be any integer value even including 0.
We will make sure that is clear in the documentation.
2. No.
[2017-07-19 20:09:48]
if I follow .... the key value can be greater than 5000 ? us that right ?
[2017-07-19 20:35:34]
Yes and the documentation has already been updated. It gives you the specific ranges of values that can be used.
Date Time Of Last Edit: 2017-07-19 20:35:43
