Date/Time: Wed, 15 Jan 2025 16:08:12 +0000
Price Volume Bar Custom Request for SC
View Count: 641
[2017-07-18 03:30:53] |
User24187 - Posts: 54 |
Requesting another option where the user can enter a base volume quantity per bar for a chart, which would then be used to determine the width of the bars on the chart. For example, if the base vol is set as 500 lots, a bar with 1000 lots would appear as twice the width of the base vol bar. I asked an experienced SC based programmer to work on this but he said that only SC can add this feature. |
[2017-07-20 07:47:01] |
We will see about this later on. It is not something we can get to anytime soon. Please check back with us in about six months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
