Date/Time: Wed, 15 Jan 2025 16:24:13 +0000
Possible issue with color bar and Flex Renko (SC Version 1580)
View Count: 762
[2017-07-18 01:51:08]
onnb - Posts: 662
See attached image.
The chart is Flex Renko and has study that uses Color Bar.
It looks like the color bar is not coloring the renko bar properly.
This was working ok in previous version 1368 was the last one I saw it workring.
The image is from 1580.
Private File
[2017-07-18 02:01:04]
This issue is resolved in the latest prerelease.
We do not understand why these posts are often hidden from you. There is nothing private about them that we can see.
[2017-07-18 02:44:18]
onnb - Posts: 662
Will this be included in 1585 ?
Usually if its related to client projects I will hide them just to be on the safe side. So it depends. In this case I could have just hidden the image I suppose.
[2017-07-18 02:50:38]
Yes. 1585.
