Date/Time: Wed, 15 Jan 2025 15:32:18 +0000
SVXY split
View Count: 1026
[2017-07-17 14:47:07] |
User28682 - Posts: 233 |
SVXY and UVXY have splits, how do we get these charts to adjust for this? Thanks TT |
[2017-07-17 15:19:17] |
We need to make sure these are already adjusted in our system. If they are, you just need to re-download the data by going to the chart and selecting Edit >> Delete All Data and Download.
[2017-07-17 15:33:51] |
I did what you said and nothing changed.
[2017-07-17 15:50:40] |
We will make sure these are adjusted after the close.
